Chevrolet Malibu
2001 engine knocking
Old Jan 30, 2008 | 1:11 PM
WHEELIN's Avatar
Default 2001 engine knocking
I have a 2001 Malibu with a V6 with 107K miles. Everytime after starting the engine knocks very loudly until it is at normal operating temp then it goes away almost completely. It drives fine, has plenty of power, not hesitation...all that good stuff, its just the noise is annoying and i feel it is going to break down very soon. Is this a common problem for this vehicle? Is this a sign of a top end rebuild? Please give comments and suggestions on what to do.i am mechanically inclined, but do not know everything about engines, by any means, so any ideas will help. Thanks.
Old Jan 30, 2008 | 1:22 PM
MalibuMaxxSS's Avatar
Default RE: 2001 engine knocking
I have yet to hear an older MAlibu with a 3.4 or 3.1 that dont knock.....well maybe an exageration but lots do....prolly a lifter, make sure the oil is good andthe head gasket is not leaking....
Old Jan 30, 2008 | 6:43 PM
WHEELIN's Avatar
ORIGINAL: MalibuMaxxSS
The oil is good and changed regularly. I know the head gasket isn't blown. what is the best way to check if it is leaking? Now if it is a lifter... is this something i should be concerned with? Will it cause any damage later? Can't you adjust those?
Thanks
Old Feb 1, 2008 | 8:10 PM
golfer's Avatar
If it's knocking when you first start up and quiets down ... it's thedreaded crappypiston slap commonly found with these vehicles.
Been running mine that way for6 1/2noisey years.
Old Feb 2, 2008 | 1:59 PM
WHEELIN's Avatar
ORIGINAL: golfer
will it lead to any other problems that will cost more than taking care of it now? I guess its good to know you've been fine for that long. i suppose this ones been doing it for a good2 or so (that i know of cause its my girlfriends car)
Old Feb 3, 2008 | 10:59 PM
golfer's Avatar
Short of tearing down the motor to rework the pistons .... I would probably run it as is ... unfortunately it sounds like crap.
Old Feb 10, 2008 | 10:07 PM
WHEELIN's Avatar
alright, Thanks!
Old Jun 9, 2009 | 1:31 PM
sketch222's Avatar
Golfer is right! I have 2001 Malibu 3.1, and it has the piston slapp. Have run it 130K now with that damb noise.
Peruvian
Feb 2, 2010 8:00 AM
Bill's Dad
Oct 20, 2009 7:51 PM
dei3rules
Jul 18, 2009 8:56 PM
kmatassa
Apr 1, 2009 6:57 PM
piniongear
Jul 9, 2008 10:31 PM
