Chevrolet Malibu
2003 Chevy Malibu Transmission wont shift past 2nd gear.
Old Dec 19, 2012 | 11:06 AM
eromore189's Avatar
Exclamation 2003 Chevy Malibu Transmission wont shift past 2nd gear.
So i have tried to resolve this issue with no luck. It began when my car began to over heat. So i pulled over added water and continued. But when i get on the freeway it wont shift pass 2nd gear. I have tried switching out the transmission speed sensor and adding trans oil as needed, But no luck. Any help would be great, thanks.
Old Dec 22, 2012 | 10:45 PM
go-part's Avatar
Former Sponsor
Bulletin No.: 02-07-30-022B
Date: October 20, 2003
TECHNICAL
Subject:
Service Engine Soon (SES) Light On With DTCs P0716 and/or P0717, P0730, P0753, P0758, P1860, P1887, or other Miscellaneous Transmission Trouble Codes Set (Repair Wiring at Transaxle Wiring Pass-thru Connector)
Models:
2000-2004 Buick Century, LeSabre, Park Avenue, Regal
2003-2004 Buick Rendezvous
2000-2001 Chevrolet Lumina
2000-2004 Chevrolet Cavalier, Impala, Malibu, Monte Carlo, Venture
2004 Chevrolet Classic
2000-2002 Oldsmobile Intrigue
2000-2003 Oldsmobile Aurora
2000-2004 Oldsmobile Alero, Silhouette
2000-2004 Pontiac Bonneville, Grand Am, Grand Prix, Montana, Sunfire
2001-2004 Pontiac Aztek
2000 Toyota Cavalier
with 4T65-E, 4T40-E or 4T45-E Transaxle (RPOs MN3, MN7, M15, M76, MN4, MN5)
Supercede:
This bulletin is being revised to add the 2004 model year as well as the Chevrolet Classic model. Please discard Corporate Bulletin Number 02-07-30-022A (Section 07-Transmission/Transaxle).
Condition
Some customers may comment that the Service Engine Soon (SES) indicator is illuminated and that while the light is illuminated, transmission shifts are extremely harsh.
Cause
These types of conditions may be caused by an intermittent connection at the transaxle 20-way connector to the wiring harness interface.
Correction
If a DTC was recorded and the Freeze Frame and Failure Records back it up, a problem existed at one time with the wiring and/or the connectors between the transaxle and the PCM. Therefore, a thorough inspection and/or repair of the wiring harness at the transaxle 20-way connector for one or more of the following conditions may be warranted.
^ The wiring harness is stretched too tightly or other components are pressing on the connector body itself causing a downward pressure on the connector body and possible intermittent contact of the wiring terminals. Ensure proper clearance to any other components and wiring (i.e. hoses, battery cables, etc.).
^ The terminals are not fully seated into the cavity of the connector body.
^ The male terminals in the transaxle portion of the connector may be in the wrong position (i.e. bent).
^ The female terminals may be loose and are not making proper contact. Check the tension with the proper terminal tester from the GM Terminal Test Kit J 35616-A or J 35616-92. If the tension is low, replace the terminal. Do not try to re-form the terminal.
^ The crimp of the terminal to the wire may not be satisfactory (i.e. loose, over insulation, etc.).
^ The wiring connector is not properly seated and locked in position. Ensure proper seating of the connector into the transaxle and that the connector is properly locked in place.
Bulletin No.: 0O-07-30-002B
Date: July, 2002
TECHNICAL
Subject:
Slips, Harsh Upshift or Garage Shifts, Launch Shudders, Flares, Erratic Shifts and Intermittent Concerns, DTC P1811 or P0748 Set (Replace Pressure Control Solenoid Valve Assembly)
Condition
Some owners of the above vehicles with a HydraMatic 4T65-E transaxle may comment on harsh upshifts or harsh garage shifts, soft shifts, shudders on hard acceleration, or shifts erratic. These conditions may appear intermittently or set a DTC P1811 or P0748. During diagnosis, a low or high line pressure (actual versus desired) may be observed.
Cause
The above condition may be due to any one of the following which may affect line pressure output:
^ Sediment inside the pressure control (PC) solenoid valve, causing the PC solenoid valve to mechanically bind.
^ Sediment in the valve body, causing the torque signal regulator valve to stick.
^ Incorrect transaxle oil level.
Read these two service bulletins
Old Sep 20, 2013 | 4:20 AM
omatsola brown's Avatar
I drained oil yesterday and actually found oil to be less than 5 lts now what oil can be used will synthetic oil work in this transmission ?
Old Oct 15, 2013 | 11:40 PM
Tech from Northeastern Transparts's Avatar
get it scanned for codes. Start there. Don't throw parts at it.
Old Mar 30, 2014 | 12:12 PM
rkriebel850@windstream.net's Avatar
I have 2003 Chevy Malibu that won't shift into low gear. It will manually shift into decond but not into third and drive. Inpluged computer and checked all wires to transmission and none were broken. Code comes up 1004 when put on machine. If I put a used computer in will I have to have it calibrated??
jrod1993
Apr 9, 2015 6:10 PM
r3333d
Jul 24, 2014 9:16 AM
jacked2000
Mar 15, 2014 9:40 AM
J P
May 22, 2011 9:26 PM
BigFish246
Astro
Jul 19, 2009 7:14 AM
