Chevrolet Malibu
2005 Malibu- electrical problem again?
Old Jul 10, 2012 | 8:21 PM
Kansas55's Avatar
Default 2005 Malibu- electrical problem again?
My Malibu Classic is a 2.2 Ltr. automatic with 140K miles. It has symptoms similar to what others have posted. The car engine starts and the windows, radio, a/c, fuel guage, etc. are not working. The check engine light is on. Sometimes the cruise goes out while driving interstate and the warning bell will chime. Then the cruise starts working on its own. I've already replaced the ignition switch twice in the 6 years I've owned this car. The last replacement was 3-4 years ago. This is what temporarily cured this problem previously. It's about $300-350 to get it fixed again. Is this something that can qualify for the lemon clause? Can GM be convinced to fix their problem here?
Old Jul 10, 2012 | 8:30 PM
kevinkpk's Avatar
Sounds like body control module, but you need to post the codes.
Old Jul 11, 2012 | 8:00 AM
Kansas55's Avatar
Default post codes?
I'm not a mechanic and I don't have diagnostic equipment.
Old Jul 11, 2012 | 10:48 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I'm sorry you are experiencing these issues with your Malibu vehicle. Have you had the vehicle inspected recently? Would you please provide the last 8-digits of your VIN, so I may look into this further?
Louis
GM Customer Service
Old Jul 12, 2012 | 7:57 AM
Kansas55's Avatar
Default Vin
the last 8 digits are 5M252088.
Old Jul 14, 2012 | 8:07 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Thank you for providing the last 8-digits of your VIN. I have researched your vehicle, and there are currently no known issues, based on your description, for 2005 Malibu vehicles. There are also no open recalls on the vehicle.
"kevinkpk" offers a possibility. It may also be an electrical issue (loss of connection, corrosion, etc.). These are just suggestions, they are not meant as a diagnosis. I encourage you to consult with a certified technician for an official diagnosis. They will be able to assist you further after inspecting the vehicle.
Please keep us posted.
If you have any additional questions and/or concerns, please feel free to contact me privately.
Louis
GM Customer Service
Old Jul 16, 2012 | 10:24 AM
scorpion48's Avatar
Default This has been a problem for a while
GM has had problems with these cars for a while. Since 98-99 or so there has been problems with the computer systems. This is nothing new for '05. I owned a '99 Olds Alero had all the same problems you have described. I changed the ignition cyl. the BCM, even did a bypass on the system which worked the longest, about 6 months then it started the same simptoms again. I don't understand why(other than it would cost a bundle to change things) they didn't fix this problem sooner. If you look at any of the GM cars in that line they all have this problem to some degree. The Alero, Grand Am, and Malibu that I have read about on various forums. I've learned to just steer clear of these cars. I really don't think there is a fix and I had a few repair shops that didn't even want to deal with my Alero. I got lucky though the dealer I bought the Alero from actually bought it back from me for what I paid and what I put into it. Pretty sad for a car that only had 30,000 on the odometer.
Old Jul 17, 2012 | 7:44 PM
Kansas55's Avatar
Default Back to the dealer
Took the car to the local dealer this a.m. to have it looked at. It's now evening and I've heard nothing from them yet.
Old Jul 29, 2012 | 10:29 PM
Kansas55's Avatar
Default The fix needs a fix
Bentley Chevrolet in Florence, AL finally checked my car and determined that it needed a new battery. After the replacement, they said it tested OK and that it was good to go. I paid them $229 for the tests and the battery. When I drove the car home, the same problems occurred- the ac, radio, windows, cruise, all quit briefly and then came back on after about a minute. The check engine light came on and stayed on. We immediately took the car back to Bentley. They tested again and found nothing wrong. Bentley said there were no codes and the car was ready to go. We drove the car on a long trip and the same problem happened 4-5 times. The duration of the outage wasn't long and the car got us to the destination.
I have no confidence in Bentley Chevrolet's ability to fix the problem.
Old Jul 30, 2012 | 7:29 AM
kevinkpk's Avatar
Sounds like body control module, keep taking it back.
mesatule
Oct 2, 2014 2:23 PM
alexanderzjs
Jun 10, 2013 12:47 PM
run4ever
May 15, 2012 11:11 AM
nolegirl10
May 2, 2012 9:37 AM
2004MaxxLT
Mar 21, 2009 10:24 AM
