Chevrolet Malibu
2005 Malibu will not start
Old Nov 29, 2010 | 11:02 AM
experimentalist's Avatar
Default 2005 Malibu will not start
Hello!
I have a 05 Malibu that was running OK yesterday, but this morning, it will
not start. The battery seems to be OK; I get 11.5VDC on the terminals
and my windows/wipers/stereo work as normal.
The only warning light on the dash is the Check Engine light, which is solid,
and that (as I recall) is normal. I think it typically disappears after ignition.
When I turn the key, I hear a rapid "click-click-click" until I stop turning
the key. In-between the clicks, the 'check engine light' turns off/on. The
starter does not (sound) as though its trying to crank the engine.
I checked some of the fuses, they were OK. I am unable to test any relays
at this point, but I will be prepared to do so later tonight. I have not tried
to jump-start the car as I think the battery is fine; I presume if the battery
was failing, the car would at least try to crank.
Any tips on what I can check myself? I was thinking of renting a code-
reader for the OBC-II and doing a little deeper diagnosis maybe tomorrow.
Thanks for your time & suggestions! It's appreciated!!
- Experimentalist
Old Nov 29, 2010 | 6:00 PM
jayro's Avatar
Make sure your battery and starter cables are tight. Next take battery and out and have someone load test it. If its ok, remove starter and bench it.
sutchman
Feb 9, 2013 1:40 PM
LS1RatRod
Dec 30, 2011 4:12 PM
tonynikki0181
Mar 12, 2009 12:47 PM
marilove
Oct 13, 2008 8:15 PM
