Chevrolet Malibu
2007 LTZ coolant leak
Old May 30, 2011 | 11:32 AM
k0urnel's Avatar
Default 2007 LTZ coolant leak
New to the site and have used the search thread and came up with no answers. My 07 malibu ltz has a coolant leak which I cannot seem to find. No drops under the car but I have to keep putting it in every couple days and the fan runs alot longer then it should. I know a coolant pressure test would probably tell me more, but was wandering if this was a common thing. Any input would be great.
Old Jun 4, 2011 | 6:52 PM
k0urnel's Avatar
Here is a picture of my car!
Old Jun 4, 2011 | 7:49 PM
Tyger's Avatar
Could be a cracked head bolt or gasket, check the oil. If it's grey and thin there's coolant getting into the system.
Old Jun 4, 2011 | 8:48 PM
k0urnel's Avatar
Oil seems normal. On really hot days the fan stays on alot longer even after the car is turned off. I can smell coolant burning as well.
Old Jun 12, 2011 | 8:34 PM
Tyger's Avatar
Did you find the problem yet?
Old Jun 20, 2011 | 5:36 PM
k0urnel's Avatar
Finally found the leak. Its leaking from where 3 hoses connect right below the resovoir. Im hoping its only one of the hoses. Leaking right where the clamp is. Pain is the *** to get to though.
Old Jun 21, 2011 | 4:25 PM
k0urnel's Avatar
Fixed today. It was the coolant Tee pipe that was cracked. Part was less then ten bucks.
Old Jun 30, 2011 | 8:09 PM
Tyger's Avatar
Glad you fixed it! Those little things are a big pain!
Old Sep 17, 2013 | 7:49 AM
snpiee's Avatar
Default 2007 Malibu LTZ Coolant Loss
I also have a 2007 LTZ that is loosing coolant. I've never had a good chance to dig into the problem but its been like this for about 2 years now. Since I'm so busy I just add more coolant. The way I know I'm low on coolant is I start hearing "moving water" sounds. When sitting in the car I can hear a sound like water running in the pipes, especially on acceleration. I did spend about half hour once to try and find any leaks but found nothing. Looked just about everywhere. Everything is dry. There were a few questionable spots on the engine but seemed more like oil. The engine temperature gauge though, has never been higher than normal. I will double check those hose connections under the reservoir when I get a chance.
dlaroche
Oct 29, 2014 7:17 PM
jmitchell
May 17, 2011 11:21 PM
Gadawgfan
Mar 29, 2010 9:22 PM
95wt
May 30, 2008 3:07 PM
bc56845
Nov 29, 2006 2:12 AM
