Chevrolet Malibu
2008 Malibu will not start or crank
Old Jun 16, 2014 | 4:39 PM
schommy98's Avatar
Default 2008 Malibu will not start or crank
I've read all through these forums and have not found the answer to this problem. Here is the troubleshooting I have already done.
-Replaced battery - I knew it needed to be replaced because of corrosion (blue stuff) on the negative terminal and verified that it had 12.4 - 12.6 volts. Although now it reads 11.6.
-Traced to the Starter relay and completed the circuit. The engine DID crank! However will not start.
-Tried the anti-theft reset (even though the anti-theft light was not on)
-Tried starting in Neutral/Park, jiggling the shifter, 20 or so times
I'm not sure how to trace it down further.
Old Jun 16, 2014 | 9:09 PM
sledge.impy's Avatar
crankshaft position sensor?
https://chevroletforum.com/forum/mal...p-66004/page2/
Old Jun 18, 2014 | 5:43 PM
Official GM Rep
Hi schommy98,
I'm sorry to hear of the difficulties that you are experiencing with your Malibu. I would like to look further into your concern and contact your dealership on your behalf for further assistance. Please feel free to send us a private message with your full contact information, VIN, current mileage, and dealership name if any extra help is needed. I look forward to hearing from you!
Kristen A.
Chevrolet Customer Care
Old Sep 14, 2014 | 8:24 PM
krick211's Avatar
Having the same problem with my 08. beginning to think i should have bought a Toyota
Old Sep 15, 2014 | 10:20 AM
Official GM Rep
Hi krick211,
I'm sorry to hear that you are also experiencing this concern with your Malibu. I will be sending you a private message in order to further discuss your concern. Hoping to hear from you soon!
Kristen A.
Old Aug 6, 2015 | 8:40 AM
schommy98's Avatar
I should have updated this a long time ago. I had the vehicle towed to the dealer and the problem ended up being the ECM (Engine Control Module). It sits right in front of the battery.
Old Oct 21, 2024 | 11:55 AM
sammorris's Avatar
Default Same issue
Originally Posted by Chevrolet Customer Service
Hi schommy98,
Kristen A.
I changed the crank position sensor and still won’t crank
las5233
Jan 22, 2014 10:03 PM
summit800
Jul 22, 2013 7:57 PM
icemanthe1
Sep 25, 2012 5:18 PM
hondalover
Feb 1, 2011 4:06 PM
85k5d
K5 Blazer
Feb 12, 2010 5:59 PM
