Chevrolet Malibu
2011 Malibu Gas Cap Type
Old Apr 18, 2024 | 4:07 PM
CB2003Suburban's Avatar
Default 2011 Malibu Gas Cap Type
Trying to replace gas cap on my 2011 Malibu with a 2.4l and I'm finding 3 different types and was wondering if anyone knew which one was the good fit for mine.
One is a Vacuum Only Cap and the other is a Pressure Vacuum Cap and a OE Equivalent Vacuum Only Cap. I don't want to grab the wrong one.
Thanks in advance,
Chris...
Old Apr 18, 2024 | 10:52 PM
get a cap from the chevy dealer; then you know its correct.
are you trying to fix a evap system fault?
Old Apr 19, 2024 | 7:57 AM
Yes, the car has a P0442 EVAP code so I was going to try to replace cap again. The first cap I replaced doesnt seem like it fits quite right. I was just wondering if the 3 choices I found on the auto parts place mattered which one I picked. I'll call my local Chevy dealer and see if they have one.
Old Apr 19, 2024 | 9:17 PM
the code sets when a small leak is detected in the system. The pcm test the system by closing the vent solenoid and monitoring the fuel tank pressure sensor. If a pressure change is not detected the po442 sets.
clear the dtc, install the new cap. if the code resets have a shop pressure up and seal the system with a smoke machine. If the flow meter of the machine zeros out...there is no leak...the fault is possibly the fuel tank pressure sensor.
Old Apr 20, 2024 | 11:54 AM
I'm gonna call the dealer and see if I can order a new part fit for the car. The cap I bought was a carquest cap from an auto parts place. I also replace the purge solenoid and the canister purge valve with no luck. Hopefully the correct cap for the car fixes it.
gmlover
Feb 1, 2016 4:50 PM
Borders15
Dec 3, 2010 4:14 PM
juventusfc
Nov 14, 2008 10:12 AM
adam
Nov 9, 2007 4:18 PM
ddrsi
Oct 1, 2007 4:23 PM
