Chevrolet Malibu
Brake Problem
Old Mar 14, 2010 | 5:29 PM
MBrady's Avatar
Default Brake Problem
Just replaced front brake pads and rotors on a 2005 malibu classic. No lines were opened. Used C Clamp to retract pistons. Now the brake pedal feels spongy and will press to the floor. Bled system with no change ( no sign of air) Appreciate any help. Thanks
Old Mar 14, 2010 | 10:30 PM
kizzelwhix's Avatar
May sound obvious but after bleeding/changing the brakes, with the car running and NOT moving pump the brake pedal several times until the pedal is stiff.
then check fluid level, obviously.
Old Mar 15, 2010 | 10:56 AM
MBrady's Avatar
Thanks for the reply, i have tried pumping the brakes but no change. Fluid level is good. Could there be something in the abs system that I am missing? Thanks again
Slobby Baymon
Nov 12, 2013 11:52 PM
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
tom5170
Mar 19, 2010 11:57 PM
