Chevrolet Malibu
GM Recalls Older Model Vehicles (2004, 2005, 2006, 2008 Malibu) to Fix Power Steering
Old Apr 1, 2014 | 11:05 AM
2004MaxxLT's Avatar
Default GM Recalls Older Model Vehicles (2004, 2005, 2006, 2008 Malibu) to Fix Power Steering
GM Recalls Older Model Vehicles to Fix Power Steering
2014-03-31
DETROIT – General Motors informed the National Highway Traffic Safety Administration today that it would recall more than 1.3 million vehicles in the U.S. that may experience a sudden loss of electric power steering assist.
If power steering assist is lost, a message displays on the Driver Information Center and a chime sounds to inform the driver. Steering control can be maintained because the vehicle will revert to manual steering, but greater driver effort would be required at low vehicle speeds, which could increase the risk of a crash.
Models subject to safety recall are the:
Chevrolet Malibu: All model year 2004 and 2005, and some model year 2006 and model year 2008 and 2009 vehicles
Chevrolet Malibu Maxx: All model year 2004 and 2005, and some 2006 model year
Chevrolet HHR (Non-Turbo): Some model year 2009 and 2010 vehicles
Chevrolet Cobalt: Some model year 2010 vehicles
Saturn Aura: Some model year 2008 and 2009 vehicles
Saturn ION: All model year 2004 to 2007 vehicles
Pontiac G6: All model year 2005, and some model year 2006 and model year 2008 and 2009 vehicles
Service parts installed into certain vehicles before May 31, 2010 under a previous safety recall
Depending on the vehicle, GM will replace free of charge either the power steering motor, the steering column, the power steering motor control unit or a combination of the steering column and the power steering motor control unit. Customers who previously paid for repairs of these parts would be eligible for reimbursement.
In addition, 309,160 non-turbocharged Chevrolet HHRs from the 2006-2008 model years (and several hundred 2009 models) and 96,324 Saturn IONs from the 2003 model year that are not subject to these recalls will be given lifetime warranties for replacement of the electronic power steering motor.
“With these safety recalls and lifetime warranties, we are going after every car that might have this problem, and we are going to make it right,” said Jeff Boyer, vice president, GM Global Vehicle Safety. “We have recalled some of these vehicles before for the same issue and offered extended warranties on others, but we did not do enough.”
The 2004-2007 Saturn ION, the 2009-2010 Chevrolet HHR and the 2010 Chevrolet Cobalt are included in previously announced recalls for ignition switches that may not meet GM specification for torque performance. Repairs for the ignition switch and power steering assist may require separate dealership visits depending on parts availability.
GM expects to take a charge of up to approximately $750 million in the first quarter, primarily for the cost of recall-related repairs announced in the quarter. This amount includes a previously disclosed $300 million charge for three safety actions announced on March 17 and the ignition switch recall announced Feb. 25.
Old Apr 1, 2014 | 11:28 AM
2004MaxxLT's Avatar
This recall is specifically for vehicles that have electric steering, which means they have no power steering fluid.
This is long over due. Most all of these vehicles have some kind of front suspension and steering problems that no matter how many times are fixed, reoccur.
I wonder now if they will also finally address the light housing melting due to heat from the front DRL/turn signal lamps on the 2004, 2005 Malibu. The original investigation focused on the lamps and sockets, but because of the high heat from the lamps, the plastic lamp housing itself actually melts:
Date Investigation Opened: MAR 20, 2009
Date Investigation Closed: AUG 12, 2010
NHTSA Action Number: EA09004
Component(s): EXTERIOR LIGHTING
Manufacturer: General Motors LLC
SUMMARY:
GM designed the MY 2004 and 2005 Chevrolet Malibu and Malibu Maxx vehicles with a daytime running lamp (DRL) system that uses the same filament (the high power filament of a dual filament bulb) as the front turn signals. The high power filament operates at full battery voltage when functioning as a DRL. The DRL is illuminated whenever the headlamps are off, increasing the duty cycle of the front turn signal bulb. The MY 2003 and earlier Malibu vehicles (Malibu Maxx was not manufactured for sale in the U.S. prior to MY 2004) used a headlamp based design, operated at a reduced voltage, for the DRL function; GM reverted back to this design on the MY 2006 and later Malibu and Malibu Maxx vehicles. Filament based bulbs have a finite life (hours of illumination) for any given operating voltage. As a result, increasing the duty cycle of a bulb typically decreases the life span of the bulb. GM identified and addressed two front turn signal/DRL and rear turn signal bulb quality issues early in MY 2004 production, however vehicle warranty claims for failed bulbs continued to occur. To address the high warranty levels of bulb failures (90% of the warranty claims submitted to ODI by GM were bulb failures and 10% were socket failures), GM issued a technical service bulletin in March 2006 advising dealers to use a new specification of bulb when addressing service failures, and to also inspect the electrical sockets for thermal damage and replace if necessary. In June 2006 (after subject vehicle production ended) GM changed the turn signal bulb specification to that of the TSB bulb in vehicle production also. To date, ODI has not identified any allegations of crash, injury, or fire related to the alleged defect even though the subject vehicles have experienced 5 - 6 years of field exposure. ODI's analysis of consumer complaints, both VOQ and manufacturer, shows a declining trend. The warranty rate for turn signal bulb replacement is high however statistical analysis of the warranty data suggests that the majority of the original equipment bulbs have already been replaced. GM conducted a safety recall (06V-263) for MY 2004-2005 Cadillac XLR to replace the front turn signal/DRL bulbs and the electrical sockets. However GM advised that the turn signal/DRL bulbs/sockets on the subject vehicles differ from those on the recalled XLRs in several respects, including using bulb sockets with four electrical terminals as opposed to three, which improves the electrical connection, allows the bulb to operate at a lower temperature, and adds stability to the bulb in the socket; operating at a lower voltage, which increases vehicle bulb life; using vented headlamps, which allows bulbs to run cooler than those installed in a non-vented XLR headlamp; and using a clear bulb, which runs cooler than the amber bulbs installed on the XLR. Additionally, the warranty claim level related to subject vehicle sockets is unremarkable compared to other defect investigations into defective socket assemblies. A safety-related defect trend has not been identified at this time. Further use of agency resources does not appear to be warranted. Accordingly, this investigation is closed. The closing of this investigation does not constitute a finding by NHTSA that a safety-related defect does not exist. The agency will take further action if warranted by the circumstances. See attached report for further information.
LinuxMan
Jun 27, 2009 3:13 AM
mobilemodding
Apr 3, 2009 3:21 PM
veegosse
Uplander
Oct 19, 2008 5:38 PM
BMAdkins
Mar 5, 2008 11:45 PM
