Chevrolet Malibu
hesitating when taking off from a stop
Old Jul 13, 2023 | 8:45 PM
LilMsPris's Avatar
Question hesitating when taking off from a stop
I need help, I have a 2017 Malibu LT, NO check engine light is on but having problems with car hesitating when taking off from a stop. I have cleaned throttle body, new MAS, air filter changed, complete oil change, new spark plugs, Auto Zone had suggested a treatment I believe it was a fuel treatment can't remember for sure but poured it in gas tank, it was by Lucas that I do remember. I do live in the desert and I know heat can affect engine performance we have been in triple digits but it didn't do this last summer, I have had my Malibu 2 years and it has almost 68,000 miles on it. Car has not showed any signs of overheating, if I don't drive during the day but do when the sun goes down it seems to drive fine. Any suggestions? I'm worried my car doing this is going to mess something up and not having much luck finding anything online. I'm on a very tight budget and having to do a lot of the work myself so any help is much appreciated.
Old Jul 15, 2023 | 2:47 AM
oilcanhenry's Avatar
You need to have someone run some OBD II CODES on your Malibu. Stock plugs will go 100K or more. Did you ,mean MAF, not MAS, although it is likely the same. Lots of code won't send off your dash light.
Old Jul 15, 2023 | 2:57 AM
LilMsPris's Avatar
There are no codes. I went ahead today and put in a new O2 sensor. It's still doing it just not as bad. MAS was for mass air flow sensor.
Old Jul 16, 2023 | 8:22 PM
It may be an air leak is my guess. Is there anywhere you can plug in a vacuum gauge?
Old Jul 16, 2023 | 9:39 PM
LilMsPris's Avatar
I don't even have a vacuum gauge
Old Jul 17, 2023 | 12:08 AM
There are no codes.
can you read live data? What are the fuel trims?
Sounds a lot like sagging fuel pressure
Old Jul 17, 2023 | 8:37 AM
LilMsPris's Avatar
I have no idea ,how can I find that out?
Old Jul 18, 2023 | 1:40 AM
As MMJ said, you can use an OBD II code reader to check your fuel trims. You may have a bad fuel pressure regulator or a fuel pump going bad. You can rent a fuel pressure gauge. It must be between
55 to 62 PSI with 60 PSI as Ideal.
Old Jul 18, 2023 | 1:50 AM
They are cheap to purchase, but it's not easy to hook one up on a non-carbuerated system, i.e. a fuel-injected system. They can give you readings that can come in very handy, but F-I systems don't often come with the port outlet to hook them up to as you would have with a carb. There are adaptors that work on some F-I vehicles, but not all.
llmmoore01
Feb 10, 2022 9:17 PM
jmay11
Mar 22, 2020 10:20 AM
Bobbo1
Jun 24, 2017 6:00 PM
jackun06
Jun 19, 2017 11:54 AM
rasparks0967
Apr 25, 2017 4:41 PM
