Chevrolet Malibu
Malibu - 2004, intermittent weak start
Old Nov 7, 2011 | 1:06 PM
rtarb41323's Avatar
Default Malibu - 2004, intermittent weak start
Greetings all!
2004 Malibu, 93,000 miles on it. 90% of the time, the car starts just fine. Once in a while, when I turn the key, the vehicle has a very "weak" start, and the motor barely turns over. Once it turns over, though, everything is fine.
Could it be a bad starter motor?
Old Nov 7, 2011 | 5:38 PM
EinST's Avatar
Welcome to the forum. It sounds more like a weak battery (how old?) or battery cables or connections going bad (there may even be corrosion eating away inside the cables).
Old Nov 7, 2011 | 8:43 PM
rtarb41323's Avatar
Hello EinST,
Thanks for your response! I had the battery replaced this past summer, so I *think* it's not the battery itself, but I will definitely check the cables!
Old Nov 8, 2011 | 1:03 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Welcome to the forum! Let us know how it goes when you check the cables. If this does not fix the issue, please feel free to message me.
Breanne
Chevrolet Customer Service
Old Nov 8, 2011 | 2:38 PM
kevinkpk's Avatar
When it's weak starting, is the car warm? As in has it been running awhile, then trying to restart it "hot"?
Old Nov 8, 2011 | 2:45 PM
kevinkpk's Avatar
If it was cables ect, I'd think it would have your problem 90% of the time, however best to do the simple things first. As I posted, is it "hot" when you try to start it, but no problems cold? The piece atop this starter is the solenoid. Usually with a hot start with weak cranking is caused by the solenoid contacts.
Old Nov 9, 2011 | 7:58 AM
rtarb41323's Avatar
--> Indeed! When I have starting problems, they happen when the car is "cold" (I.E. hasn't been run in 8 hours or more, like when I go home from work, or when I start it in the morning).
Old Nov 9, 2011 | 12:55 PM
kevinkpk's Avatar
I'd say battery.
Old Apr 14, 2012 | 10:00 AM
GM Fixer's Avatar
I agree, sounds like battery
JoeJr
May 26, 2011 3:54 PM
JohnnyG
Sep 3, 2009 10:44 PM
Foxracing
Mar 17, 2008 7:35 PM
mountandriver
Feb 8, 2006 8:22 PM
