Chevrolet Malibu
Overheating
Old Jun 6, 2012 | 7:44 PM
cb1's Avatar
cb1
Default Overheating
My daughter has a 98 malibu, It keeps blowing out anti-freeze on her every 2 months or so. She drives it daily and it does not do it consistently. I have replace the belt, pump, thermostat, reservoir cap and have flushed the radiator. I do bleed it while I fill it up after it has an issue. Both fans run and show no problems.
The way it usually happens is, I check her fluids often and never have to add anitfreeze. She will be driving it and when she comes to a stop, the car blows a lot of anti-freeze out of the reservoir. She says the temp gauge stays around half way and nevers shows hot. I get it home and fill/bleed it and run with the a/c on for over a 30 mins and its fine.
Does anyone have an idea what it could be?
Thanks in advance.
Old Jun 7, 2012 | 8:10 AM
RacerX's Avatar
needs head gasket replaced or she is driving in the wrong gear overheating the transmission.
Old Jun 7, 2012 | 4:22 PM
cb1's Avatar
cb1
If it was the head gasket, wouldn't it blow water out every time not just once every couple months of driving or so? And she drives the car in drive not second or first.
Old Jun 7, 2012 | 4:41 PM
kevinkpk's Avatar
I'd suggest a partial plugage. Pull the radiator, (I know you've flushed it) flush the system again, and replace the thermostat.
Old Jun 11, 2012 | 12:12 PM
adribolla's Avatar
Default Over heating
Hello, My son's 99 Malibu also has an issue with overheating. The heads have been done as well as a new radiator, new thermostat, new hoses, and 2 new fans. I have heard tell of a bleeder valve on these cars. Could someone tell me where it is located please?
Old Jun 16, 2012 | 11:05 AM
cb1's Avatar
cb1
On the 98 3100 it is right above the water pump. There's a pipe that comes up out of the pump with a plug with a bleeder on it. Be careful when tightening it up cause it can snap easily.
Old Jun 16, 2012 | 9:37 PM
kim's Avatar
kim
Check radiator cap might not be able to hold pressure.
jessejames
15
Nov 16, 2014 3:19 PM
87_caprice305
May 2, 2007 6:12 PM
Theflyer1
Dec 16, 2006 4:01 AM
jpp
Jun 5, 2006 11:30 PM
CliffGriffin
Jan 28, 2006 10:58 PM
