Chevrolet Malibu
P0446 Code on 2000 Chevy Malibu Help?
Old May 8, 2014 | 1:29 AM
kobe3006's Avatar
Default P0446 Code on 2000 Chevy Malibu Help?
have a 2000 Chevy Malibu With Engine Code P0446 (Evap emission control system vent circuit)
I changed out the I replaced the Purge Valve Solenoid down by the Evap Canister.
Still same Issue.
Anyone know how to test this?
How do I test the Vent Valve under the hood byt the egr? I think one end has a plastic tube that goes under the car to the evap canister and the other goes to the PCV on the valve cover to the engine.
Ideas? thanks
Old May 8, 2014 | 4:06 PM
kobe3006's Avatar
Ok I tested my Evap Purge valve Solenoid by the throttle body with a Vacuum Pump I hooked one end to the side where it goes into the valve cover. it held pressure so its good. Gonna look for a plugged hose down by the evap canister
Old Feb 23, 2019 | 10:59 AM
tbb2's Avatar
15 Year Member
Did you sort out why your ODII threw PO446?
samster35
Cobalt
Apr 10, 2013 10:33 PM
Aaron@Airlift
Aug 2, 2012 9:33 AM
Concours98
Apr 10, 2012 3:23 PM
arminkropp
Uplander
11
Apr 1, 2010 10:57 PM
Cleaner
Apr 8, 2009 10:32 AM
