Chevrolet Malibu
Starting Disabled Service Throttle
Old Nov 2, 2017 | 9:33 PM
Charlie Lipford's Avatar
Default Starting Disabled Service Throttle
Hi, I have a 2015 Chevy Impala LTZ Limited, and it just read Starting Disabled Service Throttle. It shut down and wouldn't crank. Anybody know what this is, how to fix it, and what it cost? Thanks
Old Nov 3, 2017 | 4:38 AM
oilcanhenry's Avatar
Sounds like you have a problem with your electronic throttle control system. New cars dont use cables, they are "fly-by-wire". Make sure your battery is working real good. If it is OK you may need to replace your throttle control valve to fix this. I dont know what that will cost but it wont be cheap at a shop. Its probably covered under your warranty anyhow, if its still good.
Old Dec 18, 2019 | 8:44 AM
A Presley's Avatar
As dumb as it sounds... Lock then unlock your doors. Mine did that as I was driving and lost all power. I googled it and it pulled up a different car but it still worked. Hope that helps a little bit.
Old Aug 30, 2020 | 7:51 PM
TashaRenee Woods's Avatar
I really was about to cry bc I didn’t know what to do try this and it worked thank you thank you so much..
Old Aug 30, 2020 | 7:56 PM
Sharondah Presley's Avatar
I'm so glad this was helpful for someone. 😍
Old Apr 25, 2021 | 2:04 PM
Eddie Ornelas's Avatar
Default You sir!!!!
Are a life saver!!!!!! I appreciate it with good goin back to you thanks!!!
Equinox Owner
Jan 4, 2022 11:45 AM
Kris Boyle
May 16, 2019 10:46 PM
greenfire
Oct 22, 2013 5:07 PM
StormH2Oguy
Jan 6, 2012 7:01 PM
