Chevrolet Malibu
timing codes
Old Apr 18, 2026 | 8:07 PM
joevolgmann's Avatar
Default timing codes
i have a 2017 Chevy Malibu 1.5 turbo. ill start from the beginning. 4 months ago my vacuum pump went. took apart the valve cover and believe i found all the pieces. replaced the vacuum pump and went about my business. well had an oil leak because i didn't change the valve cover gasket ATM because i didn't have one. so 2 months later i did the valve cover gasket. my problems started. p0016 p0017 p06d3. OK... do some research. reluctors move a lot of times when this blows. watched some videos and moved it accordingly to the video with the qr code up and the reluctor up. was good for a week. codes came back. so replaced the oil pump solenoid and cleaned my pick up screen because it was gunked up. good for a day. so today update ive replaced oil pump solenoid, timing chain and hardware, camshaft "exhaust because of the bad reluctor", both cam phasers, both vvt solenoids and pigtails, intake cam position senor, changed the oil with pf64 filter for double check valve and higher oil psi. car ran good for 2 hours. it always acted up when warm. so p0016 and p0017 and p06de came back and reduced engine power. car is hesitant and idle. what am i missing? please help. out of options.
dbittle
Nov 26, 2024 10:30 PM
corvairbob
Oct 12, 2021 9:49 PM
jtinker101
Sep 5, 2021 5:19 AM
Gumby22
1988 - 1998 (GMT400)
Jul 13, 2020 12:09 PM
WhIzAtIt
Jun 23, 2008 2:48 PM
