Last edit by: IB Advertising
Browse all: Interior
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Gas Pedal Sensor
Step by step instructions for do-it-yourself repairs.
VERY dangerous reduced engine power issue!!
#171
Is this a common occurrence?... Yes I have a Chevy HHR 2011 and I am experiencing this thing. On my way to work I typically drive at the speeds of 65 to 70 and out of nowhere the came start sputtering significant engine loss and on the HUD I view SERVICE ENGINE LIGHT, SERVICE ESC, and other things (can't remember them all lol) I have taken the vehicle to a Chevy Dealership they gave me the run around. This change my view dramatically on all Chevy vehicles. At the end of the day I still had the issue, I didn't receive any customer service at the dealership. I hope this forum thread is taken notice if anyone is attempting to purchase one. DON'T !!!!
#172
I have the same issue with my 2001 Malibu. It only happens when the temps are under 25 degrees. I do not know what to do. I am a single mother with one vehicle. My car does not start anymore since this morning! My child is at day care and I am at work. No family anywhere in the near vicinity. I called the dealer that I purchased it from and NO help at all. Engine Power Reduced/ESC Off/traction
#173
Good Morning, I have a 2010 Black Chevy Equinox
It just happened to me this morning as I was "warming up" my car to come to work. It started fine, but 2 minutes into it on, it started shaking and the "Engine Power is Reduced" message came on. Then "Service Stabili Trak" message came on. I put the car in reverse and it didn't move at all. I then pressed the gas pedal a lil harder and it moved. I got to work (which is less than 2 miles from home) and the car didn't go past 12mph no matter how much or how hard I pressed the gas pedal. I called my Chevy Dealer and he was quick to say "I don't know what that means, but ok I'll get you prices" ???? Really???? How you going to get prices if you don't know what's wrong with my car yet? I've had enough either with the car (not to mention, I have gone to the dealer 5 times since December 29th that the "seatbelt" alert doesn't shut up even when I have it on!) or with this dealership. Someone please help and direct me to the right people.
#174
So I took my traverse in today. We are in Maine, and my mechanic is somewhat familiar with this. He cleaned the air intake system & pcv system. He said the lines were full of condensation which flips the computer system. It cost me $147. I'm crossing my fingers that this is the answer. Just thought I'd share this will all of you. Good luck!!
#176
Reduce Engine power
I HAVE HAD THE SAME PROBLEM WITH MY TRUCK I HAVE FIXED PROBLEM I Replaced the modal on pedal and the one under hood now my truck runs like it did in on when I drove it off the lot .First check all grounds and clips make sure they are clear of dabree and moisture. I had codes ran and replaced both modules on pedal and on motor it cost me about 250 in parts if that advanced auto part has the parts cheep replaced them both and now my truck is a beast again .hope this helps don't go to dealer they will just give u the runaround they wanted to change the throutel body wire cluster for 650.00$ it is not that .
I have had the same issue with my 2011 Equinox. Last winter it happened several times. Each time I left the motor off for about 10 minutes, then had no more issues when the weather warmed. 3 different dealerships told me to bring it in the next time it happened - and just drive it in, don't turn off the motor. I live in a rural area. I cannot drive the car at 10 mph for 150 miles to the nearest dealership. All 3 told me to not bother to bring it in unless I was having the problem. Monday, it was 19 degrees here. And, it happened again while I was driving 75 mph on the Interstate with a truck behind me. VERY SCARY. I still have no answer from anyone.
#177
Same issue
My car does the same thing. It started and it was exactly what one of the many recalls examined. Took it in still happens. It is dangerous and one day people are fining to die and its all Chevys fault. This is a recall. It's lemon cars when it happens to this many people and no one can fix it. They don't know what it is. And to top it off the answer they offered T the dealer. Buy a new car!!! Never ever another Chevy.
#180
