Chevrolet Malibu
wiring diagram 2005 malibu
Old Feb 27, 2009 | 8:42 PM
tonynikki0181's Avatar
Default wiring diagram 2005 malibu
Anyone know where I can find a wiring diagram for a 2005 malibu? I am wiring a remote start on my wife's malibu and need a wiring diagram to wire it.
Old Feb 28, 2009 | 3:20 PM
shawnvw's Avatar
Banned
MAKE SURE YOU TEST ALL WIRES USING A DVOM BEFORE HOOKING THEM UP!!!!
WIRE COLOR LOCATION POL.
Battery 1
Red/Black Driver's Kick Panel or At BCM (1) Positive
Ignition 1
Pink Ignition Harness Or Back Fuse Block Conn 4 Pin D3Positive
Starter 1
White Ignition Harness Or BCM Connector #2 Pin 56 Resistor
Accessory 1
Brown Ignition Harness Or Back Fuse Block Conn 4 Pin C8 Positive
Parklights Negative
Brown/White BCM Connector #2 Pin 5 (3) Negative
Brakes
White BCM Connector #1 Pin 24 or 42 Positive
Horn
Tan BCM Connector #2 Pin 14 Negative
Tach
Lt.Blue At Ignition Coil 2 Cyl
Lock
White BCM Connector #1 Pin 66 or 67 Negative
Unlock
White (with 1.5Kohms resistor) BCM Connector #1 Pin 66 or 67 Negative
Trunk
Lt Blue (4) BCM Connector #1 Pin 16 Negative
Unlock Driver
Tan Driver's Kick Panel Reverse
E-Brake
Lt.Blue BCM Connector #1 Pin 59 Negative
Disarm
Lt.Green (620 ohms Resistor) BCM Connector #1 Pin 35 Negative
Rearming
Type 1
Trunk Disarm
Tan BCM Connector #1 Pin 4 Negative
Rear Defrost
Lt.Blue BCM Connector #2 Pin 68 Negative
Head Lights
Tan/White BCM Connector #1 Pin 29 Negative
Wiper Protection
Yellow (5) At Wiper Switch Open
Old Mar 2, 2009 | 6:43 AM
Thanks for the wiring help! Much appreciated!
Old Mar 10, 2009 | 12:39 PM
What is BCM and where in the car is it located?
Thanks again.
Old Mar 10, 2009 | 4:46 PM
shawnvw's Avatar
Banned
BCM = Body Control Module
located in the center console behind panel on the passenger side
Like I said at the beginning of the last post....make sure you test and confirm that the wires you are hooking up are the right wires. DO NOT use a test light...damage can occur if you probe the wrong wire. Use only a voltmeter
Old Mar 11, 2009 | 12:37 PM
I can not find a lt. blue wire near the ingnition for the tach. I have a 2005 mailbu with the 2.2 dual overhead cam four cylinder. Where else can I tap the tach wire?
Old Mar 11, 2009 | 2:58 PM
Also, is there another spot to tap the ignition(at the key switch), the starter, and the accesory wires other then at the key switch? There's not alot of wire there, and it is a really tight area to work in.
Thanks in advance
Old Mar 12, 2009 | 11:09 AM
Ok, disregard the last two posts. I got the ignition wires and starter wires hooked up. But, I am having two problems that I can not figure out.
First, when I hit the remotew start feature, it runs then shuts off.
Second, when I hit the unlock button it does not work. The lock part works, but the unlock does not.
Last thing, what does this mean about the unlock wire: (with 1.5Kohms resistor) and what do you mean by: Pin 66 or 67 Negative-which should it be, 66 or 67?
Old Mar 13, 2009 | 10:46 AM
Ok, I got the unlock to work right by installing the resistor. But I stilll can't get the remote start to work right. I have even hooked up the disarm wire with a resistor and it still dies after the remote start starts the engine.
Old Mar 13, 2009 | 10:54 AM
slls's Avatar
You have to bypass security.
