Platform: A-, G-, & W-body
'01 coolant leak
Old Feb 17, 2012 | 12:31 PM
toddb1's Avatar
Default '01 coolant leak
my name is todd,thanx for being here! have an '01 monte carlo ss with 44k on it.
recently developed a coolant leak.im not a mechanic but i got a coolant pressure tester and hooked it up and saw a couple leaks.red fluid around valve cover next to thermostat.around water pump and then it was actually dripping onto ground from somewhere close to firewall on drivers side,coolant i guess.
iv'e had this car a year before that it was garaged for "awhile".
thank you for any help at all !!!
Old Feb 17, 2012 | 5:34 PM
EinST's Avatar
Welcome to the forum. The cause is usually the intake manifold gaskets in that era V6 engines. Do a web search for "TSB 03-06-01-016."
Old Feb 19, 2012 | 3:56 PM
toddb1's Avatar
Red face GM's recall for faulty gaskets
Thank you EinST for the direction.
im sure theres no way they would fix my car,being 10 yrs. old and a second owner, would they?
question#2 is: if doing one gasket anyway wouldn't it be smart to do both upper and lower intakes while in there?
not a mechanic so this might be a stupid question,sorry.
Old Feb 20, 2012 | 12:40 AM
EinST's Avatar
For free? No. TSBs contain information for technicians. Whether or not you pay for the work done by them depends on your warranty status. When you replace the lower intake manifold gaskets, it's assumed that the upper gasket is replaced along the way. If you decline, they'll note that in the repair order to cover their ***.
dlaroche
Oct 29, 2014 7:17 PM
95wt
May 30, 2008 3:07 PM
formulalt1power
Mar 14, 2007 6:34 PM
ffdaryl
Mar 1, 2007 2:52 AM
bc56845
Nov 29, 2006 2:12 AM
