Platform: A-, G-, & W-body
1998 Lumina Huming Noise - I need help bad
Old Apr 13, 2010 | 10:50 AM
mikey613's Avatar
Default 1998 Lumina Huming Noise - I need help bad
Hi I have a chevy lumina 98 that has a huming noise that sounds like its coming from the front wheels... its a loud huming noise that starts at 20kph+ when i turn right the noise goes away.... i just changes the left wheel bearing but i feel the vibration right under the gas pedal and it sounds like thats where the noise is coming from but I just changed it... what do you think it is?
UPDATE- i jacked up both side and on the passenger front tire there was no movement when i shook the tire at 12 and 6 and maybe 1/8 th of an inch at the 3 and 9 position. the driver side front tired 12 - 6 didnt move much at all but 3 and 9 i could move it easy. any idea?
Old Apr 13, 2010 | 6:31 PM
MDTAHOE's Avatar
Professional Mechanic
It could possibly the other bearing. Or the bearing in the trans at the axle. Get a stethoscope from the auto parts store, safely put the car on jack stand , have someone get in it put it in gear. Carefully listen for your noise.
mtm6042
Avalanche
Jul 22, 2021 6:20 PM
Den7bronco1
Aug 2, 2015 1:04 PM
98Tahoe4x4
Dec 15, 2012 12:52 PM
bavant
Jan 16, 2012 2:12 PM
mikeythe613
Jul 17, 2010 7:51 AM
