Platform: A-, G-, & W-body
2001 monte ss wont start in wet conditions
Old Apr 23, 2011 | 10:59 PM
1968ss's Avatar
Default 2001 monte ss wont start in wet conditions
my 01 ss last couple of days we had heavy rain car wont start just keeps cranking you can smell the gas build up when cranking but when conditions dry up the car fires right up need help
Old Apr 24, 2011 | 8:13 AM
EinST's Avatar
It sounds like an ignition problem. Try cranking at night and then watch for a spark leak and get the ignition coil packs and wires checked out?
Old Apr 24, 2011 | 9:36 AM
lumina_guy's Avatar
It seems like you getting water some were in the ingition
get a multimeter if you have one and check the coil pack wires resistance and compare them to the specs for the car . also you may want to check the gap on the spark plugs and check to see if they need to be changed. That may also cause a no start condition when wet..
abates2k
Astro
39
Jan 21, 2015 1:29 PM
otrava
Jul 10, 2013 3:57 PM
yamiyalo
Jul 19, 2011 4:46 AM
marbar64
Oct 17, 2010 3:39 PM
CPT_Purge
Oct 8, 2008 10:54 PM
