Platform: A-, G-, & W-body
93 Lumina need some advice.
Old Jan 13, 2020 | 6:31 PM
InjuredPride's Avatar
Default 93 Lumina need some advice.
Just bought a 93 lumina and it has some issues. I am having a hard time pinning down exactly what. I was told by the person I bought it from that it needed a fuel pump or possibly an 02 sensor.
The car has the following symptoms currently.
It will start right up normally. After being driven however it will have issues starting again. Predominantly when it has been warmed up and then parked briefly. It will turn over just fine but wont catch. When it finally does it usually surges for a moment and then will slowly return to a normal idle.
it has not died while.being driven. Only when parking and starting it up again. Time it takes to start up has been highly variable but usually will get going again after 10 to 15 minutes.
Service engine light has come on twice now. First time it briefly flashed at a light and the second time it came on while idling and stayed on until i turned the car off. Went away again when i got it to start up again and so far has not come back on.
Car has 190,000 miles on it give or take and seems.to have been fairly well maintained.
Otherwise the car sounds and runs pretty well. I have not had a chance yet to check the basics beyond knowing it needs an oil change but my last car was a 4 cylinder neon. I am still learning about this car and its engine.
looking for any advice and tips on how to properly diagnose and fix my issue.
Old Jan 13, 2020 | 8:30 PM
kevinkpk's Avatar
Do you know what the SEL light is? Do you get gasoline from the the same place all the time? What you post acts like a blockage to the fuel pump, or fuel pump.
Old Jan 13, 2020 | 10:31 PM
Yes as I mentioned the SEL has come on briefly twice but hasn't stayed on long enough to pull codes. I was told that the fuel filter had been replaced recently so I'm assuming the pump is the most likely problem. I'm just not used to a pump working like this. My other car when they went, they just died completely. The working most of the time.isnwhat keeps throwing me off. Thank you for replying.
msp0088
Nov 26, 2019 6:49 PM
RLwiley87
13
Sep 18, 2019 11:27 PM
73shark
Aug 20, 2016 4:01 PM
mikeatpriestlake
11
Apr 11, 2014 10:00 PM
JMelick
Apr 2, 2010 3:39 PM
