Platform: A-, G-, & W-body
97 Lumina Fuel line o-ring?
Old Sep 3, 2013 | 10:19 PM
MXer746's Avatar
Default 97 Lumina Fuel line o-ring?
I have a 97 3.1l Lunmina. Turn the key on and fuel comes gushing out of the fuel line/fuel rail connection, under the drivers side of the intake manifold, where the fuel line threads into the rear fuel rail. My question is; is there supposed to be an o-ring at that connection where the line threads into the rail? Because mine is missing one if there is. If not then I suppose that either the fuel liine, or the rail is warped from engine heat. But I'm betting there's a o-ring there. I can't iimagine GM not putting a o-ring there. Anybody know?
Old Sep 12, 2013 | 8:55 PM
CONTECH's Avatar
I just Googled "1997 fuel line" and found a parts place that has a picture of a metal fuel line with a steel nut and it does show an o ring at the end of the tube.
Old Sep 19, 2013 | 2:19 AM
MXer746's Avatar
Yes it did. And I replaced it as it had flattened out over time. Had the local autoparts store match one up for about $1.50. Also put on new intake plenum and EGR valve gaskets. Runs good after I had to replace the starter, where my son wore it out trying to start it, when it wouldn't start, because it wasn't getting any fuel!
harley3348
Oct 21, 2014 8:23 AM
deepstuff
Sep 23, 2013 6:37 PM
NMguy
Jan 28, 2012 12:16 AM
itstheiceman
Apr 8, 2008 4:48 PM
arbiestsheft
Aug 5, 2007 4:21 PM
