Platform: A-, G-, & W-body
99 Lumina no crank/no start
Old Oct 13, 2025 | 2:20 PM
Heckfire's Avatar
Default 99 Lumina no crank/no start
Mine is the 3100. Everything comes on electronically. I can hear the fuel pump come on but when I turn the key to start I get nothing. Not a click, nothing. I turn it off and so long as I'm patient enough to sit for 7 or more minutes then the next time I go to start it fires up without issue. This started out of the blue. Nothing has been added or taken off. Just one day I came out, got in and no crank. It seems to be happening more frequently the longer this goes on so I want to try and correct it before one day it doesn't start at all please any advice would be greatly appreciated. TIA
Old Oct 13, 2025 | 7:43 PM
Rednucleus's Avatar
Maybe starter is dying. Next time it hapens, have someone hold key in start position while you gently tap starter with a hammer - if it starts then time for a new starter motor.
How many miles on car and has starter been changed in the past?
Old Oct 14, 2025 | 5:50 PM
Heckfire's Avatar
Idk the starter seems fine when it actually cranks over. It doesn't seem slow or like it's having trouble. It is just whenever I first try to start it I get nothing I have to turn the key back off and just sit for like 5 minutes or more, then it starts up without issue. It's got 214,xxx miles and as far as I know the starter hasn't been changed. I've only had it maybe 6 months. It did sit for about 2 years before I got it without being started or anything. Butji put a battery in it and fired it up. It smoked and knocked for a second and went to running like normal and has up until this started.
GMCotech2
Sep 8, 2015 9:57 PM
zrafferty
May 4, 2015 10:02 AM
bigpop8365
Mar 1, 2012 7:53 PM
luminalumina
Dec 12, 2011 11:14 PM
dahar42
Jul 7, 2007 12:36 PM
