Platform: A-, G-, & W-body
GM vats bypass module on 98 chevy lumina
Old Sep 10, 2011 | 5:17 PM
rpulley's Avatar
Default GM vats bypass module on 98 chevy lumina
Hello this is my first post here
I have purchased the Vats bypass module which is found here:
GM VATS or PASSkey II Bypass Module For LS1 and LT1 | eBay
and I was wondering if anyone has any clue where to install this at on a 1998 Chevy Lumina. If anyone knows please help me out so I can fix my security issue.
Thanks
Rick
Old Sep 10, 2011 | 6:09 PM
EinST's Avatar
Welcome to the forum. The product image made me curious enough to look at the manual. It's certainly different way of doing it, directly sending the fuel enable signal to the PCM instead of simulating the presence of the key (actually the resistor pellet on the key). The fuel enable circuit 229 on your vehicle is the DK BLU wire that goes from the theft deterrent module to PCM connector C1, pin 55. Good luck.
Old Sep 11, 2011 | 6:24 PM
rpulley's Avatar
I don't know where the theft deterrent module is, I don't have a service manual can anyone help me in locating where the TDM is?
Thanks
EDIT: Actually from googling i believe it is behind the glove box but what does it look like?
Old Sep 11, 2011 | 6:28 PM
kevinkpk's Avatar
Thanks
I think it is part of the ecm
Old Sep 11, 2011 | 7:52 PM
rpulley's Avatar
I looked under the hood under this box that I read on another site and I looked for the dark blue wire and didn't see it (this box was supposed to be the ecm) So I'm just lost as to where this stuff is
Old Sep 11, 2011 | 8:04 PM
kevinkpk's Avatar
The anti theft CRAP is part of the ecm
Old Sep 13, 2011 | 8:00 PM
rpulley's Avatar
well i cut a dark blue wire in the BCM and hooked up the part, and I thought it was working but today the car stopped starting again so I dont think it was the right wire. My view is tho if I cut a wire that wasn't right something wouldnt be working right on the cars computer? Im not sure im just not
Old Sep 13, 2011 | 8:42 PM
kevinkpk's Avatar
Refer to post #2 I didn't refer you to cut anything
Old Sep 14, 2011 | 6:23 AM
rpulley's Avatar
then what is it your telling me to do because i have to cut the fuel enable wire to wire it up to the module i purchased so it will send the 50hz signal........
Old Sep 20, 2011 | 5:22 PM
rpulley's Avatar
Sorry for the double post but i fixed the issue.
I have the module i bought on ebay installed and I also had to install the resistors under the dash.....thanks for your help
rickywashere
Nov 17, 2010 3:28 PM
sara145
Jun 10, 2010 12:21 PM
