Platform: A-, G-, & W-body
Power steering issues
Old Mar 31, 2021 | 7:17 PM
00montecarlo's Avatar
Default Power steering issues
I replaced my leaky rack and pinion in my 2000 Monte carlo LS recently along with the high pressure line. It was working fine for a week or so then I was having problems with hard left hand turning, but turns fine to the right. I thought the pump may have gone bad so I replaced it then I had no power steering either way. I figured I had gotten a bad rack since I bought it on eBay. Replaced it with one from a local parts store, same thing. I had flushed and bled the system after replacing all the parts and I still have nothing. I pulled the return line off and it is pumping through so I'm not sure what the hell is going on.
Old Mar 31, 2021 | 7:45 PM
kevinkpk's Avatar
Check for leaks, as in it could be sucking air into the system.
Old Apr 1, 2021 | 7:54 AM
hanky's Avatar
Sometimes things go wrong in spite of our best efforts and this includes replacing one defective part with another assuming , "It is new and has to be good".
Those of us that have been burned with defective parts learned to get parts from a dealership (OEM).
There are a lot of good aftermarket parts out there and there are also a lot of bad ones too!
If price is the only consideration, consider the trouble with now having to return what you hoped was a good new part. The extra cost for the dealer part the first time is worth the cost , believe me! I does sound like you received some questionable quality parts.
Old Apr 1, 2021 | 2:02 PM
Sounds like your rack is full of air. There may be a leak but it is full of air. How did you bleed the system?
Old Apr 1, 2021 | 5:41 PM
At first I turned the steering wheel back and forth multiple times with the engine on and off. After that I put my mityvac over the reservoir, but since I don't have the correct attachment I didn't work very well
corvairbob
Mar 8, 2021 7:58 AM
ChevyHeavy
Jan 31, 2021 7:05 AM
Skunked again
Jan 15, 2016 6:42 PM
Thatoneguy1119
Oct 1, 2014 9:48 PM
TinaSterr
Oct 8, 2007 11:56 PM
