'06 Colorado codes, needs help/info
Old Feb 19, 2015 | 9:07 PM
1southernknight's Avatar
Default '06 Colorado codes, needs help/info
Hi all,
I have an '06 Colorado 5 cylinder. I was driving home the other night, and on a twenty mile drive my truck shut off six times. I has done this a few times over the past month or so. When it would shut off, I would pop the hood 'wiggle' the battery cables and it would crank again. It would not turn over again until I did this. The other night it was late. The next day after work I came home and it would crank and run a minute or two and shut off... pop the hood and 'wiggle the cables... crank and run a minute or two and shut off.
I borrowed a code read and got these codes:
P0014 Exhaust Camshaft Position System Performance
P0171 Fuel Trim System Lean Bank 1
P0601 Power Control Module Internal Fault
I'm not sure where to start, but I've had the suggestion that it was a combo of the battery and fuel filter having possible water in it due to the recent weather.
I live in MD and the temp has dropped and been below 30 for a week or so now if this help with the above info. And yes, the six stops the other night on the side of the interstate with a -12 windchill was lots of fun.
Thanks in advance,
J
Old Feb 20, 2015 | 8:07 AM
Welcome to the forum.
First I would check and clean the battery cables and check your grounds. Second, if you post your question in the Colorado section you will get more views.
landjet
Colorado
Jun 24, 2015 2:40 PM
silveroak94
Aug 3, 2014 9:03 AM
sphilbrick
May 5, 2014 1:24 PM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
jair143
Sonic (Aveo)
Mar 3, 2011 5:31 AM
