engine light and Transmission Temperature
Old Feb 24, 2012 | 12:36 PM
Sylvester Howard's Avatar
Default engine light and Transmission Temperature
Check in light stays on and the transmission Temperature hovers above
200 degrees in about five minutes of driving and 15 minuted of idling do anyone have any clue what might be the causie for this ,I had the transmission fluid changed approximate 4 months ago at a Chevy dealership
Old Feb 24, 2012 | 8:50 PM
ChevyFreak's Avatar
Default Welcome!
Welcome to the Forum!!
It helps to post the model and year of the vehicle that you are referring too, so that you may be pointed in the right direction. Keep in mind that the "New Member Welcome Area" is not typically used for help threads. You will get much better attention to your question, and thus responses, simply by posting in the correct section specific to your vehicle. Good luck!!
itchy2000
Sep 18, 2014 5:28 PM
cupofchicken
Dec 24, 2011 8:28 AM
o.valdez
Dec 17, 2011 10:46 PM
chefboubou
Uplander
Apr 6, 2009 2:28 PM
june82000
Feb 10, 2008 6:32 PM
