engine light and Transmission Temperature
Check in light stays on and the transmission Temperature hovers above
200 degrees in about five minutes of driving and 15 minuted of idling do anyone have any clue what might be the causie for this ,I had the transmission fluid changed approximate 4 months ago at a Chevy dealership
It helps to post the model and year of the vehicle that you are referring too, so that you may be pointed in the right direction. Keep in mind that the "New Member Welcome Area" is not typically used for help threads. You will get much better attention to your question, and thus responses, simply by posting in the correct section specific to your vehicle. Good luck!!
cupofchicken
Dec 24, 2011 8:28 AM
o.valdez
Dec 17, 2011 10:46 PM
