1927 Chevrolet Truck Amp / Generator
Old Jul 31, 2021 | 3:39 PM
  #11
dlelmp1579's Avatar
Thanks for the reply - the generator was rebuilt 2 years ago - so I would assume everything was good at that time. The truck really hasn't been running consistently for the last 2 years - I put it in 2 parades and take it for short rides, but other than that - I have been slowly (2 years), trying to figure out why it was having a hard time starting. I think I finally figured all that out with the help of this forum and some research. I don't see an actual "brush" - I can loosen the screw on the outside and it loosens up a metal piece on the inside that I can move around -but it doesn't really move much. I will have to try and take some picutres of what I am talking about. As for your reply on the communtator - If i know what your talking about - there are 3 of them - they all look fine. IF there are not 3 of them - then I am not sure what your taking about and I will have research that more - but the whole thing was rebuilt 2 years ago. Hope that helps.......thanks again. r/dave
Old Jul 31, 2021 | 3:40 PM
  #12
dlelmp1579's Avatar
Okay, so a quick search on commutator - there might be only 1 - but that looks fine also..........
Old Jul 31, 2021 | 4:16 PM
  #13
kevinkpk's Avatar
Might be 3 brushes, but all of them ride on the commutator. Based on Oldchevy's reply about adjusting the brush for voltage , makes sense. You might want to consider an external voltage regulator unless you want to keep it all original, and I wouldn't blame you for that. One final thing, since it starts, sometimes fine, other times not, did you check the belt tension?
Old Aug 1, 2021 | 6:19 AM
  #14
dlelmp1579's Avatar
Morning, Thanks for the reply. Thanks to OldChevy for telling me about the contacts that could be bad in the kill switch - I took that out and the truck will start consistently now - problem there solved. I was just trying to figure out the generator and the AMPs - before I adjusted the "3rd brush" the amps was reading + 18 - 20 when running and some said that would "boil" the battery. After the adjustment - it is reading about - 2 to - 10 depending on what I turn on and off - so to me that just means that the battery is not being recharged - which I can live with since I am not doing too much w/the truck right now. I car around an extra battery also. I was just trying to get the AMPs to read properly when running so that it does recharge the battery.
I agree with you Kevinkpk - I want to keep it all original as possible - it is coming up on 100 years old and even though it might run better with an upgrade in some systems - I am having fun with it as it is. Neighbors have told me to change it out to a 12 volt, update the bed and side rails and I always say - NO - I will struggle with the issues I have - as long as I understand what they are and how to get around them when I go to car shows/parades or just driving around.
On this Tuesday coming up - I am joining a local classic car group - so I am looking for more help with my issues that are closer to home.
Thanks again for all the thoughts on my issues. I will keep you updated as I move along. R/dave
GoRacers
Jun 25, 2019 11:39 AM
woodyt
HHR
Apr 1, 2017 9:19 AM
Whiskey_Sauer
Sep 24, 2016 4:03 PM
mikeythe613
Apr 21, 2010 5:19 PM
mightydog4805
Oct 16, 2007 4:38 PM
