1969 chevy problem
Old Jul 14, 2012 | 8:19 PM
Curiouscat's Avatar
New User
Awaiting E-mail Confirmation
Default 1969 chevy problem
Here's our problem the thing idles perfect but once out on the road it stalls in and out as were driving we can't even make it out of the driveway without it stalling and if we do it shift gears twice maybe 3 times then starts putting out and we have to turn around and come back.
Old Jul 15, 2012 | 8:33 AM
kevinkpk's Avatar
Is the choke opening after it is warm?
Old Jul 15, 2012 | 8:28 PM
KiaraDragon's Avatar
New User
had to register new name can't login into my other account and admins wont get back too me
yes the choke opens after warming up
Old Jul 15, 2012 | 10:28 PM
Did this start all of a sudden or was something done to the engine before it started?
Old Jul 15, 2012 | 11:35 PM
Camaro 69's Avatar
Site Ambassador
Possibly the gas is perking out of the carburetor once it's getting hot. What carb do you have? I wouldn't be surprised if you say a Quadrajet, based on what's happening. Qjets can be temperamental sitting on top of a hot engine in the heat of the summer, especially if you still have the exhaust crossover on the intake manifold open. Your float level could be set too low as well, which can cause what you're describing.
Old Jul 16, 2012 | 8:01 AM
kevinkpk's Avatar
Change filter first if it's a quad or a 2gc it will be in the carb where the fuel line goes in. If that isn't it, I'd check float drop. As posted it may be too high, and not allowing enough gas into the bowl. I don't think heat has anything to do with it, just not enough gas.
Old Jul 16, 2012 | 12:31 PM
Camaro 69's Avatar
Site Ambassador
Been there, had that with the heat/perk thing. A heat shield, or phenolic carb spacer can help if that's the issue here.
Old Jul 16, 2012 | 12:56 PM
kevinkpk's Avatar
It could be vapor lock. Is the fuel line routed with sharp bends and or close to the exhaust?
ccnchevroletforum
Oct 15, 2012 10:45 AM
ccnchevroletforum
Jul 6, 2012 12:35 PM
axe666
Mar 23, 2008 11:02 AM
mrhaney
Jun 17, 2007 7:50 PM
