1997 K1500 4x4 Centurion?
Old Feb 5, 2020 | 7:32 PM
Jasonv123's Avatar
Default 1997 K1500 4x4 Centurion?
Can anyone tell me anything about a pickup I'm looking at? A 1997 K1500 4x4 Crew cab short box? Or what it's worth? Can't find much info on it. I'll up load pics as soon as I can
Old Feb 5, 2020 | 8:36 PM
Irish_alley's Avatar
I'm here for the party
whats screwed up with the bed and cab alignment
Old Feb 5, 2020 | 8:38 PM
first thing you have to do is figure out why the bed and cab dont align.
Old Feb 5, 2020 | 9:12 PM
Jasonv123's Avatar
​​​​​​The frame is in pretty rough shape under the cab. I'm trying to figure out if it would be worth spending the money to fix it.
Old Feb 5, 2020 | 9:13 PM
Jasonv123's Avatar
It is also sitting in a rut with a flat on the passenger front it a bit so bad in flat ground.
Old Feb 5, 2020 | 9:20 PM
Jasonv123's Avatar
I hear these are know for some sagging. On this one the frame is solid looks great except for where they extended it under the cab whole bottom lip is gone in couple spots no cracks at all. I'm trying to see if this would be worth fixing.
Old Feb 5, 2020 | 9:34 PM
if the bottom lip is gone the frame isnt solid. that would explain if the cab and bed were touching on top of the bed but this damage looks side to side or is that just a camera illusion?
Old Feb 5, 2020 | 9:36 PM
can you weld? how much are they asking? brake lines prob need gone through along with fuel line
Old Feb 5, 2020 | 11:42 PM
Jasonv123's Avatar
Yeah I should have been more specific the cab in front and behind where the extension was put in (factory frame) is prefect just surface rust. It's on the extension under the cab on both side a few spots the lip is gone. Side to side it's straight it's just the way it's sitting. And I didn't notice anything with the cab and bed line until I started reading about these and took these picks. He is asking 3000 it's a buddy. Runs and drives decent front end is sloppy needs breaks motor sounds good bone dry no mess under hood. Interior is pretty fair. I have access and resources to have it fixed I just don't know if it would be worth it in the end. What are one of these worth if it was to be restored?
Old Feb 5, 2020 | 11:55 PM
the frame shouldnt have any extensions from the factory, it should all be one solid piece. if something looks like its been added then either someone modified a reg cab truck frame (not gm) or they attempted to repair a rusty frame. i have a 91 square crew cab, gm made the frame solid. if it was me i might pay 3k for one of these if the frame was in good condition along with the rest of the truck. if it was an older square then i could see someone paying 3k for it because they tend to go for a little more than the 88-98 style
