Bad Throttle Behaviour After Cleaning
Hey!
I have a problem, high RPM on ignition and and neutral. After cleaning the throttle on my chevy optra 2005, problem hasn't solved. Is there any chance that I need to perform throttle position leaning? if so, how do I do that?
Been researching for quite a while and didn't find a solution.
Hey!
I've swapped to 2 different throttles (second hand, definitely not new ones). one had the same symptoms and the third one had a leak on its water connection so at the moment we've made a bypass so the water do circulate but throttle is way better now. Do you think ordering a new one might fix the problem? AliExpress is recommended to buy a new throttle from?
BTW been experiencing a big downfall on the cars torque, I'm giving a decent amount of gas and the car's acceleration is damn lazy, on uphills I'm sweating to each 60km/h and beyond that is put of reach (on uphills)
I was adviced to try 44K fuel additive in order to clean the fuel injectors, what do you think about that?
in2pro
16
Aug 10, 2022 12:36 PM
