idle problems
Old Aug 6, 2010 | 12:15 AM
hikerrob's Avatar
Default idle problems
im working on a 89 celebrity i belive its the 2.6 v6(it`s my sisters car)its having a problem with the idle. i was told to pull off the negative battery cable to reset the system. i did that and it ran fine for a few minutes,then it went back to not idleing. any ideas? thanks rob
Old Aug 8, 2010 | 4:25 PM
2wd-K5's Avatar
check over the spark plug wires for cracks or burns, if none, then pull the spark plugs. carefull when removing the wires, if the havent been removed in a while the metal clip inside the wire could pull out of the boot before removing each wire twist it with needle nose pliers
Old Sep 5, 2010 | 4:55 PM
MountainMax's Avatar
Most of the time you have to clean out the throttle plate in the throttle body from carbon, then you have to use a tech 1 scan tool and do an idle air Contreal re-learn to get it to idle properly, if not you can disconnect the battery truck but then start the car and put it in gear and let it idle there for about a minute, should fix it.
Old Dec 13, 2010 | 2:18 PM
jackson12's Avatar
Well i think there should be some dust particle entered i think you should get that cleaned and then check that with the mechanic so that he guide you much better.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
Sethyates72
Feb 1, 2014 7:53 AM
Thermool
Jun 20, 2009 6:41 PM
turbinesurgeon
Feb 9, 2006 12:40 PM
