Siphon gas from 87 van?
Old Aug 30, 2013 | 12:14 PM
Aelanna's Avatar
Default Siphon gas from 87 van?
I have a 1987 Chevy 20 conversion van that the engine is blown in. It has almost a full tank of gas, that I'd like to siphon out and use in my other vehicles. It is not fuel injected, and I don't think it has a siphon block, but I'm not sure. What is the best way to do this? Is there a drain anywhere on the gas tank, or do I have to try to use a hose down the fill tube and suction?
Old Aug 31, 2013 | 11:17 AM
How long has the gas been sitting in the tank. It may not be usable if it has been sitting for too long. You could try letting the fuel pump do the job. Disconnect the fuel line at the engine and run a hose from the line to a gas tank, then connect 12 volts to the fuel pump and let it do the work.
Old Aug 31, 2013 | 1:22 PM
Aelanna's Avatar
It's only been off the road a couple of months. It does still run at the moment, I've moved it a few feet here and there to mow the area.
I'm not sure about the fuel pump though. Does this year have an electric fuel pump, or a mechanical one? My 77 Impala has a mechanical one I know, but unsure of this year/model van.
Old Aug 31, 2013 | 3:33 PM
SWHouston's Avatar
If you have a Carburetor, it's likely to have a Mechanical Pump, which will be mounted on the side of the Engine.
If you are Injected, then it's going to be in the Fuel Tank and Electric.
Old Aug 31, 2013 | 3:35 PM
Aelanna's Avatar
This is a carbureted van, no fuel injection.
Old Sep 4, 2013 | 7:58 PM
Aelanna's Avatar
So, given I have a mechanical fuel pump, what's the best way to get the fuel out of this thing so I can use it elsewhere?
Old Sep 4, 2013 | 10:06 PM
My 85 Blazer had a TBI injected engine with an electric fuel pump. It did look like it had a carburetor.
Old Sep 4, 2013 | 10:08 PM
Aelanna's Avatar
Mine is a 350 with a 4-barrel carb that I have to pump lots of times to start.
ahearnm
Mar 19, 2023 6:37 PM
LeeHamilton
Oct 26, 2014 9:49 PM
zuren
Sep 11, 2011 9:33 PM
Renosguy
Mar 21, 2011 2:28 PM
thundermug47
Oct 26, 2010 9:42 PM
