Trans Sport instrument cluster went black
Old Jul 20, 2013 | 12:50 AM
carbonfibercowboy's Avatar
Default Trans Sport instrument cluster went black
Recently the instrument cluster went black and the radio has locked itself (theftlock). This happened after I tried to read DTCs using a scanner. No connection were made so I checked all the fuses. Everything looked OK but when we started the engine no lamps or instrument works.
When ignition is on the MIL lights but nothing else. I have googled several hours but cant find any topic to this problem with a Trans Sport.
Does anyone of you guys have any clue to what could have happened?
Best regards from Sweden...
Old Jul 20, 2013 | 6:44 AM
It sounds like you blew a fuse. Check them with a meter if you didn't already. A visual inspection is not reliable. Could also be a loose wire under the dash.
Old Jul 21, 2013 | 1:56 AM
I'll try check the fuses once more, thanks.
Old Jul 21, 2013 | 3:01 AM
can't disagree with that.
try these
-ign1 fuse
-radio
-mall/radio/dlc fuses
Old Jul 22, 2013 | 3:52 AM
Thanks for the suggestions.
Last night I was about to show a friend when it all started working again.
Either I had got some moisture in the electronics or a lose wire or something.
I will try to remove the instrument cluster in the future to see if there are something behind it that caused the problem.
Houndawg
Jul 27, 2015 12:11 AM
Chevrolet Forum News
Jan 12, 2015 10:48 AM
jk79
Nov 30, 2010 10:16 AM
dateDR.info
Jun 28, 2005 3:46 AM
