S-10 & Blazer 1982-2005
1992 S10. Running rough and Dies when put in gear. Help!
Old Dec 9, 2012 | 10:43 PM
David_lee1993's Avatar
Exclamation 1992 S10. Running rough and Dies when put in gear. Help!
I have had this problem for a while and have tried a lot of things to fix it. But no luck. It idles really rough and shakes badly, also when I put it in reverse or drive it dies (sometimes). I have tried changing the distributor cap, rotor button, fuel filter, and spark plugs but it only made it worst. I even put some fuel cleaner in it aswell. I cant seem to figure out the problem. I also went to Pepboys but they charge $89 just for a full dynastic. Im in need of help badly. Its my daily driver and I need to get it fixed ASAP. Thanks for you help in advance!
Old Dec 9, 2012 | 11:47 PM
dhoff024's Avatar
sounds like maybe it could be out of time. when you changed the cap and rotor did you mess with anything else or move the distributor? I know when I did a tune up on my silverado I broke a screw in the distributor when I put the new cap back on and I had to take the whole distributor out and it was such a pain to get it back into time and I was having similar problem to that before we got it back in time and squared away. I could be way off on this but its just a thought.
Old Dec 10, 2012 | 7:31 AM
chevroroman's Avatar
Seems you need help from pro, it will be hard to detect it on forums
Old Dec 10, 2012 | 1:52 PM
I tightened the distributor back down after I replaced it. But didnt bother putting the timing light on it. (Could be the problem lol) I will try putting the light on it and see. If not then I guess I will have to take it to Pepboys or something. Thanks guys for your help.
Old Dec 10, 2012 | 2:15 PM
kevinkpk's Avatar
Recheck your plug wires. Put a timming light on it. Then if these don't dorrect it, I'd suspect a major vacuum leak. Do you have a vacuum guage?
macmommy
Apr 22, 2020 1:23 PM
jimbo51565
Astro
Nov 1, 2010 8:40 PM
Allan
May 4, 2010 8:55 PM
WelderManQ
Oct 14, 2009 3:20 AM
telpsar
Dec 3, 2007 9:32 AM
