S-10 & Blazer 1982-2005
1994 Blazer
Old Aug 4, 2018 | 3:24 PM
Ralpheboy's Avatar
Default 1994 Blazer
What is the location of the Fuel Pump control module? I've removed the ECM behind the glove box and it's not under it.
Old Aug 4, 2018 | 5:36 PM
kevinkpk's Avatar
Not totally sure, but I believe you should be looking for a relay
Old Aug 6, 2018 | 6:48 AM
Ralpheboy's Avatar
Thanks, but the relay has already been replaced.
Old Aug 6, 2018 | 11:00 AM
Rednucleus's Avatar
Please describe what your rig is doing for further assistance!
Old Aug 6, 2018 | 11:43 AM
Ralpheboy's Avatar
No power to the fuel pump.
No signal from the fuel pump control module to the fuel pump relay.
Ground is good, connectors are good.
Thinking I need to replace the fuel pump control module, but can't seem to locate it.
Old Aug 7, 2018 | 6:58 AM
oilcanhenry's Avatar
The only fuel pump relay or module I could find for a 1994 Chevy Blazer claims that it's mounted on the right hand side of the upper firewall.
Old Aug 7, 2018 | 7:56 AM
Ralpheboy's Avatar
Thanks, that is exactly where the relay is.
Old Aug 7, 2018 | 4:50 PM
Rednucleus's Avatar
Could this be a problem with oil pressure switch cutting off pump in car of this year?
Old Aug 8, 2018 | 7:42 AM
Ralpheboy's Avatar
Not according to the wiring diagram, the oil pressure switch is after the signal from the control module.
