S-10 & Blazer 1982-2005
1996 Blazer Engine change
Old Apr 10, 2008 | 6:36 AM
matt21191's Avatar
Default 1996 Blazer Engine change
Hey guys,i need some help bad! i have a 96 blazer with a 4.3 in it. had a rod knocking in it. so i decided to change the engine. i changed the engine and put in another 4.3 engine. but i think i did something wrong? with the key out of the ignition when i hooked the battery up all the dash gauge lights come on? it will start and run but will not shut off with the key and runs really rough??? i changed the computer with the one that went with the engine i put in. the dealer told me that would fix it but it didnt?? Could the starter have a short in it?? PLEASE HELP????? thanks,matt
Old Apr 10, 2008 | 3:09 PM
rabbit0102030's Avatar
Former Moderator
Honorably Retired Member of Staff
Default RE: 1996 Blazer Engine change
Sounds like a wiring issue, go back and check all of the wiring you did. Check to make sure everything is in its proper place, that nothing is unhooked or hooked up incorrectly, grounded improperly.......
Old Apr 10, 2008 | 5:41 PM
shawnvw's Avatar
Banned
probably have a wire shorted to power that feeds the ignition circuit
Old Apr 10, 2008 | 7:56 PM
matt21191's Avatar
thanks guys but i have done all that already. i have been through that thing like 9 or 10 times today. still the same results? someone told me to change the ignition switch. but it was fine before i pulled the motor. i think it SHOP time this time if i cant figure it out. any other ideas you might have would be apriciated. thanks,matt
Old Apr 11, 2008 | 4:06 PM
Former Moderator
It might be better just to take it to a shop then. Nobody wants to hear that, but sometimes it is just better to let a professional handle it.
Mostrix
Mar 20, 2015 5:04 PM
soulcaliph21
Jun 6, 2011 12:25 AM
stshadow
Apr 22, 2011 9:48 PM
DeHartShadow
Mar 28, 2010 10:10 PM
digdug
Feb 4, 2007 3:08 PM
