S-10 & Blazer 1982-2005
2.8 tps
Old Jan 13, 2020 | 8:12 PM
Dameon Abair's Avatar
Default 2.8 tps
92 S10 2.8 t5 trans. Here's the deal. Runs rough like a dead miss on a few cylinders. Only above idle. So here's what I have replaced. Coil plugs wires cap and button. It was due for a time up anyways. Still rough. So I started actually testing stuff. Found TPS has good 5v and good ground. Signal wire is at .4v at closed. And 2.8v at WOT. The sweep was kinda jumpy and sporadic. So I replaced and patted myself on the back. All to soon. Same stuff. WOT is still 2.8v not jumpy on the sweep though. So isolated the circuit and checked for short to ground. Tested good. Check ecm powers and grounds. What's the next step? Or just plain bad ecm?
Old Jan 14, 2020 | 1:54 AM
oilcanhenry's Avatar
I'd run a compression test on all of the cylinders.How many miles on your S-10?
Old Jan 14, 2020 | 1:05 PM
Irish_alley's Avatar
I'm here for the party
Have you checked fuel pressure?
Old Jan 14, 2020 | 4:30 PM
if you think the tps signal should be 4.8 volts at wot...maybe you should ohm check the wires
matthew donaldson
1988 - 1998 (GMT400)
May 9, 2019 9:24 PM
oks10
Apr 1, 2018 12:03 PM
gaftop1
Apr 22, 2011 11:20 AM
dreadinger
Nov 4, 2010 3:14 PM
seek14u
Sep 20, 2009 8:47 PM
