S-10 & Blazer 1982-2005
2 door chevy blazer over heating??
Old Dec 15, 2007 | 8:17 PM
ed39's Avatar
Default 2 door chevy blazer over heating??
I have a 94 cheavy blazer that overheats with the plow up. I know the truck will obviously run warmer cause the plow is blocking the air flow. but it never used to do this with the plow on. i have replaced the radiator, t stat,and fan clutch all work fine. but the truck still overheats. i dont seem to be losing coolant. so now wat should i look for??
Old Dec 15, 2007 | 8:45 PM
Default RE: 2 door chevy blazer over heating??
One possibility is that the new 'stat is bad. Another is retarded timing will cause engine to run warmer.
Old Dec 16, 2007 | 1:33 AM
ed39's Avatar
well im pretty sure the stat is good cause it runs cool when there is no plow on.....and i have been meaning to check thetiming has been running a little slugish.. thanks ill check that and getback to ya
Crubens120
Dec 20, 2014 7:56 PM
Nichole Bell
Dec 7, 2013 12:18 AM
thisnthat
Nov 20, 2012 11:36 AM
vanhan316
Aug 3, 2007 9:27 PM
jsshark1
May 31, 2006 4:49 PM
