S-10 & Blazer 1982-2005
2000 blazer - squeaky problem by passenger front tire
Old May 22, 2010 | 7:34 PM
chevyguy21's Avatar
Question 2000 blazer - squeaky problem behind the rim
i got a 2000 blazer 4x4, and a few weeks ago it started makin a squeaky noise..sounds like its literally behind the rim right where the top ball joint is and caliper, i was told a couple things such as ball joiints, rubber bushings maybe by them if there is any? upper or lower control arm, i greased all of them and still making the same noise and seems it only does it when i hit bumps and its getting worse as i drive...can anyone help me out plz? its driving me up the wall!!!
Old May 23, 2010 | 9:54 AM
nj85z28's Avatar
Senior Site Administrator
Have you inspected the shock?
Old May 29, 2010 | 4:29 PM
Siliconasp's Avatar
Default Bad Shocks
Replace your shocks and the issue will resolve itself. If unable to replace the shocks, you can test by spraying the shock main rod with some lubricating spray.. Liquid Wrench, WD-40 or the like, and take it on a bumpy test drive. The squeak should be gone, if so, you have a worn shock, and you need to replace it.
Old Jun 9, 2010 | 4:26 PM
dman001948's Avatar
Replacing them front shocks is a real bear....good luck..did all the way around at 50K. have 101K now...No squeaks..
Old Jun 13, 2010 | 11:16 AM
Bill's Dad's Avatar
possibly bad hub/bearing...
Old Jul 17, 2010 | 10:06 PM
midnight bogger's Avatar
id be willing to bet my truck that its the lower controll arm bushings just repaced mine for the samething
Old Jul 10, 2012 | 1:59 PM
JonMount's Avatar
My blazer was doing the same thing. When I checked it out, it was just a broken stabilizer link. Replaced the link and the squeaking stopped.
jbaesl
Mar 22, 2014 7:36 AM
usmarine0905
Jul 30, 2013 7:23 AM
mwdaniel
Mar 12, 2010 10:29 PM
chevy_airman88
Mar 23, 2009 9:20 AM
Hatchfinder
Jun 4, 2008 4:59 PM
