2000 blazer - squeaky problem by passenger front tire
i got a 2000 blazer 4x4, and a few weeks ago it started makin a squeaky noise..sounds like its literally behind the rim right where the top ball joint is and caliper, i was told a couple things such as ball joiints, rubber bushings maybe by them if there is any? upper or lower control arm, i greased all of them and still making the same noise and seems it only does it when i hit bumps and its getting worse as i drive...can anyone help me out plz? its driving me up the wall!!!
Replace your shocks and the issue will resolve itself. If unable to replace the shocks, you can test by spraying the shock main rod with some lubricating spray.. Liquid Wrench, WD-40 or the like, and take it on a bumpy test drive. The squeak should be gone, if so, you have a worn shock, and you need to replace it.
jbaesl
Mar 22, 2014 7:36 AM
usmarine0905
Jul 30, 2013 7:23 AM
chevy_airman88
Mar 23, 2009 9:20 AM
