S-10 & Blazer 1982-2005
2000 s10 2.2l flex bad performance issue
Old Mar 7, 2015 | 2:47 PM
00s10's Avatar
Default 2000 s10 2.2l flex bad performance issue
I recently bought a 2000 Chevy s10 extreme has 2.2l flex fuel and has bad performance issue there's little acceleration until it hits 3500 rpm give or take I have a check engine light for cam position sensor circuit low but I do not have a cam sensor anywhere on my block???? Not sure if previous owners did ecu swap or maybe motor swap? Please help
Old Mar 7, 2015 | 7:09 PM
its left of the oil filter
post the code
Old Mar 8, 2015 | 8:40 AM
00s10's Avatar
No I have looked all around there is no spot on the passenger side of block so I am assuming I am dealing with a motor swap then. Were is the engine vin? I looked last night cant find it says its rear of block just behind oil stick opening? thank you for replying and your time
Old Mar 8, 2015 | 9:41 AM
partial VIN etched on the left side of the engine block above the starter
Old Mar 8, 2015 | 12:26 PM
00s10's Avatar
OK so its not in the back its on the side?
ronboc
Jan 8, 2023 11:13 PM
adamanddiane
May 27, 2022 3:10 AM
00s10
Mar 7, 2015 1:54 PM
JoshTahoe
Jan 20, 2015 8:19 PM
itsmacintosh
Mar 7, 2010 4:11 PM
