S-10 & Blazer 1982-2005
2000 trailblazer leaking upper transmission cooler fitting
Old Dec 9, 2021 | 2:04 PM
dmedina97's Avatar
Default 2000 trailblazer leaking upper transmission cooler fitting
Hi everyone, long-time creeper but now I am in need of some help! Has anyone had to replace the fitting that the transmission line goes into the radiator with? The one I'm looking to replace is in the below link. The fitting in the link also screws into another fitting that is male/female and I am not sure if both fittings need to be replaced. I'm assuming this will fix my issue but you know what they say about assuming...
If anyone has any idea what the other fitting would be called or if I could replace that too that would be awesome. I can post a video of the leak if it helps but it's small. It's cold out and I'm ready for my heat to not reek of coolant. Thanks everyone!
https://www.autozone.com/drivetrain/auto-trans-oil-cooler-line-fitting/p/dorman-automatic-transmission-oil-cooler-line-fitting-800-605/238661_0_0
RedZilla
Feb 12, 2013 2:28 PM
thomas101
Uplander
Jun 11, 2012 7:14 PM
L1th1um67
Apr 13, 2012 9:34 PM
TomS209
Jul 10, 2010 6:33 PM
sudo
Jul 20, 2007 10:51 PM
