S-10 & Blazer 1982-2005
Transmission Kit
Old Dec 26, 2021 | 12:30 AM
Jmanc's Avatar
Default Transmission Kit
Hi guys.I have a 2000 gmc sonoma 4.3,V6 zr2 which I was told is basically same as the s10 zr2.About two weeks ago my truck started hesitating, later on I found pink fluid in my radiator. Several days later the hesitation got worse and I was told that my transmission was going out on me. Now it really struggles to move forward. It moves easier if i put it in reverse. I also notice that it takes several seconds for it to shift to drive or reverse when its parked. Right now I'm looking for a good transmission kit that has all or most of the parts that i would need. Any advice which transmission to buy? should i buy also a solenoid kit? Hope you guys can help me.T hanks
Old Dec 26, 2021 | 7:26 AM
Welcome from Florida. Did you check your fluid level in the transmission? If you saw pink fluid in the radiator, it probably is transmission fluid. You might just need a radiator and add fluid to the transmission. Do not drive it like this or you will damage the transmission if you already haven't!
JarrettM
Dec 14, 2018 2:01 AM
Robert Ziems
May 9, 2017 5:23 PM
MegaMiles
Feb 16, 2011 4:52 PM
hfdff
Feb 9, 2011 5:30 PM
mlwilli3
Jan 19, 2010 6:41 PM
