S-10 & Blazer 1982-2005
2001 s10 stalls
Old Apr 24, 2011 | 6:21 PM
fekim's Avatar
Default 2001 s10 stalls
I have a 2001 s-10 4.3L pickup when it gets to normal operating temp it quits, just as if you turned off the key. When it quits the gas and temp gauges drop all the way down to 0. The engine will crank but will not fire. After sitting for a few minutes the gas and temp gauge will go up. Than the engine will start but I have to step on the gas to keep it running. It will eventually idle by itself for a few minutes than quit again. Changed the fuel filter, fuel pump and ignition module. That didn’t help. Took it to the shop, they hooked it to the computer but the computer would not connect. Like it wasn’t even hooked up. They tried different adapters with no luck.
Old Jan 7, 2015 | 2:33 AM
doekno's Avatar
Did you happen to solve this issue?
Old Jan 7, 2015 | 1:32 PM
sledge.impy's Avatar
Sounds like when I knocked off a line near removing my serpentine belt on a 2.8 j-body. I think it was to the purge canister or something. So check all your hoses.
Doesn't quite sound like a TCC solenoid issue in the OP post.
rvankleeck
Feb 21, 2016 4:58 PM
parshath
Jul 23, 2011 9:26 PM
oilyfishhead
Apr 1, 2011 5:11 PM
bsimms
Aug 13, 2008 9:48 PM
lpruden
Dec 16, 2006 6:38 AM
