S-10 & Blazer 1982-2005
2003 Chevy s10 4.3 pickup radon misfire
Old Dec 15, 2014 | 8:27 PM
jonny123's Avatar
Default 2003 Chevy s10 4.3 pickup radon misfire
2003 Chevy s10 4.3 pickup radon misfire started off cinder 4 misfire replaced fuel filter fuel pump spider injectors solved misfire cinder 4 now have po300 replaced wires spark plugs cap roter twice new distributor crank shaft sensor coil ingntion model pvc vale even smoked it for leaks fuel pressure reads 55 psi think its the pump or o2 sensors or cats has a slight ruff idle not to bad at idle any help trying to fix would be helpful my car guy is stumped im going nuts clear the code it pops up either at an idel or when i hit 65 70 mph
Old Mar 13, 2015 | 10:58 PM
bat man1950's Avatar
Default batman1950
po300 was tps fueling to much
Old Oct 9, 2020 | 9:03 PM
Friday99's Avatar
multiple cylinder misfire??
Friday99
Oct 10, 2020 5:52 AM
mikeyman
Feb 25, 2016 7:36 PM
ncagliola
Sep 29, 2013 1:19 PM
mbryant13
Astro
Feb 13, 2012 12:04 PM
sejuron
Nov 1, 2009 8:41 AM
