S-10 & Blazer 1982-2005
4.3 firing order
Old Mar 22, 2007 | 4:01 AM
crewchief888's Avatar
Default 4.3 firing order
[&:] ok guys
this is one of those terminal dumbass questions...
i have a '91 4.3/ 700r4out of an astro van, that i dropped in my '88 s-10 blazer. i already swapped the trans tailshafts ( the truck originally had a 2.8 in it) eng/trans are in, wiring is done, plumbing for trans cooler, and eng oil coller/filter is done. somewhere along the line, i pulled the dist cap and wires offa this thing, and have no idea what the firing order/ cyl position is. this is my 1st 6 cylinder anything and i'm just looking for some help before i have to break down and buy a friggin manual for this creation too.[8D]
thanks in advance..
Old Mar 23, 2007 | 3:24 PM
CrashNburn's Avatar
Default RE: 4.3 firing order
1 6 5 4 3 2
Old Mar 27, 2007 | 2:18 PM
JPetrucci84's Avatar
ORIGINAL: CrashNburn
1 6 5 4 3 2
yup, what he said.
Old Mar 30, 2007 | 4:48 AM
kcb37's Avatar
If you have any questions like what to torque head bolts or firing orders, you can usually call autozone or advance auto parts if you have one in your area and they can print off a little peice of paper that will show it to you like the books.
Old Mar 31, 2007 | 12:50 AM
junkvw26's Avatar
if you pull the wire off .the left side on the cap is 2,4,6, nad the right is 1,3,5, that is much i can offer
Old Oct 12, 2007 | 6:59 PM
i know it's been a loooooooooooong time since i posted this, but i did get it fired up and running. it's been a long summer, and finally got to take the little beast out wheeling. my goal was to get out and not have anything that i fabricated/ engineered to break, fall off, or generally be a complete pain. well everything that i didnt do did break, including the rear end spider gears, drivers side CV shaft and a badly rusted and bent passenger upper control arm. the rear end has since been welded, the shaft replaced with a new one and the control arm replaced with a junkyard special.
Nicker
Jul 16, 2008 8:41 AM
fishdowns
Astro
Nov 13, 2007 5:04 PM
BIGDAD
Jun 26, 2007 3:49 PM
vanagon40
Apr 9, 2007 12:24 AM
Ryan Markt
Jan 28, 2007 9:39 PM
