S-10 & Blazer 1982-2005
4 wheel drive problem
Old Dec 31, 2013 | 4:17 PM
bobj1948's Avatar
Default 4 wheel drive problem
Hello all, hope someone may assist me in resolving this issue. I have a 2003 Chevy s10 4x4.
When I press the 4 hi button it stays on,it supposably locked In 4 WD. I hear a whissing noise and slight clunk, same in 4 lo, and it does go into 4 lo. Problem: the front wheels do not have power to them in either 4 hi or 4 lo. I have replaced the the actuator diaphragm under battery tray, and the transfer case vacuum switch on top of transfer case, has 3 rubber vacuum lines attached to it. These part replacements had no effect on the power loss to front wheels.
Thank you for your help. Bob
Old Mar 23, 2014 | 7:37 AM
cyrilburt.cb@gmail.com's Avatar
Sounds like you have a vacuum leak your 4wd is vacume actuated I have the same problem on my 1999 s10 its a matter of finding the leak it could be anywhere
Billy HC
Dec 10, 2018 1:59 AM
tahoejibber
Sep 17, 2010 9:25 AM
Jaysonic
Mar 8, 2010 9:07 PM
jeepman123
Oct 13, 2009 5:14 PM
Outcastz89
Mar 9, 2009 10:52 PM
