S-10 & Blazer 1982-2005
88 chevy s10 blazer!! shaking problem
Old Feb 12, 2008 | 9:09 PM
jasont483's Avatar
Default 88 chevy s10 blazer!! shaking problem
88 chevy blazer with a shaking problem in the front!! i checked out the wheel bearings, brakes and rotors, harmonic balancer, and the clutch fan .. everything checked out except for the clutch fan so i replaced it and the blazer is still shaking bad.. it starts to shake around 20mph and get worst as you speed up!! so i am thinking that it might be the torque converter.. so i am asking for any info that could help me fix the problem with my s10 blazer.. thanks
Old Feb 12, 2008 | 9:15 PM
EvansBlue's Avatar
Default RE: 88 chevy s10 blazer!! shaking problem
Have you checked the balance and roundness of the tires?
Old Feb 12, 2008 | 9:20 PM
jasont483's Avatar
yes i did do that ,, they are pretty new tires.. the shaking really doesn't fill like a tirebalance problem... thanks
Old Feb 13, 2008 | 5:36 PM
EvansBlue's Avatar
Does it happen at certain RPMs or does it happen only at certain MPH?
May be a good idea to clean your belt(s), a buildup can cause unbeleivable shaking.
Old Feb 13, 2008 | 5:38 PM
Friggen_Cobalt's Avatar
if the shaking only happens at a certain speed then you're looking at a tire balance problem. Either that or possibly an alignment problem
if it's happening at a certain rpm, then there's any # of things in the engine that could have a problem.
[/align]
Old Feb 14, 2008 | 9:28 AM
rutler101's Avatar
Yeah this sounds like an alignment problem to me. Do you have a steering stabalizer? If you do it might be bad. If not then you can try getting an alignment. If that doesnt help get a steering stabalizer. This is what most us 4xer's call a "death wobble".
Old Feb 17, 2008 | 2:16 PM
jasont483's Avatar
i finally found the problem,, i rechecked the driveline and found that the u joint was a little loose!!! thanks to all that replied to my post it was very helpful!!!!
TheDudeAbides
Nov 10, 2015 7:32 PM
rachel126
Feb 2, 2012 7:55 PM
joeywhite
Aug 25, 2011 11:21 AM
MEC407
Oct 28, 2008 6:01 PM
jasont483
Feb 17, 2008 2:20 PM
